EVO RS Headunit, brackets?
It's all there, you just need the little "harness" that takes the mitsubishi wires and clips them into your aftermarket stereo...same as any car. Then in the doors, it's wired for factory speakers (which you don't get) and you need a little (3" long) thing that clips into the factory harness in the door and makes it compatible to the + - on your new speakers.
Need a bracket for the radio and a wiring harness adapter. Also they probably going to clip the speaker wire end clips off located in the doors and splice in the new speakers to those wires. I went to GoodGuys and they did the job in about an hour. Only got the front speakers but they good so the soud is ok.
Evo23IG
39
Oct 28, 2007 03:26 PM
