.9 bar, 13psi max boost...
Old Dec 24, 2004 | 01:08 AM
RalliArtEvoVIII's Avatar
is it normal that im topping out on boost at 13psi (.9bar) if i dont have either pill in the lines. NO pills basically. I've did research on the pills and im double checking this issue. Also, is it normal that the hose plugged into the intake is plugged into the lower right corner of the valve cover cuz in some diagrams, i notice that the intake is plugged into the boost solenoid where the lines from the wastegate lead to. My BOV is plugged into that boost solenoid instead of the intake, could that be causing my low boost? I think its just my boost pill issue. Thanks
Old Dec 24, 2004 | 12:16 PM
Jakeg97's Avatar
you need the pill in the line that runs from the compressor nipple
Old Dec 24, 2004 | 12:17 PM
Jakeg97's Avatar
or cap that off and run into the bov line with no pills needed
Old Dec 24, 2004 | 04:38 PM
thanks! just making sure my lines were hooked up to the right areas
Grey Razor
Mar 21, 2011 11:55 AM
Yakshii
Sep 14, 2010 10:04 AM
robyn402
Sep 13, 2010 12:43 AM
racer135
Apr 8, 2008 03:29 PM
k270kmh
Apr 20, 2006 08:08 PM
Quick Reply: .9 bar, 13psi max boost...
