why am I still not boostin right
#46
You can't have one line (turbo/wastegate hose) to actuator and the other line running to your BOV to have your stock boost controller working, you need to have the air pressure in order for the actuator to work conjuntion to the wastegate/turbo.
__________________________________________________ ______
U mean run it to the intake and not the bov?
#49
those 2 nipples connect to the hose under the intake hose that connects to the actuator.
that helps your BOV respond a lot quicker and bit louder.
But you don't need to connect that. you could, but I say do what I said up there first then try that later.
least have your car going at the right boost.
#50
Ok I did what u told me and I gained about .2bar of boost. Topping out at 1.1bar. I ran the bov and tapped into the line coming from the compressor/wastegate to the actuator then hooked up the intake to the actuator as well. Still not boosting 19psi. What else could it be. I reseted the ecu for bout 5min and pumped the brakes about 25x. And took it for a run after. What else do I do to get about another .3-.4 of boost???? Don't think its leak cuz it held steady at 1.1
#51
that's about 15 psi...
did you try not tapping into the line coming from the compressor/wastegate to the actuator? and leave the 2 small nipples on the bov not connected?
I don't know what to say. That should cure it and have everything work properly. Because your stock actuator is working now.
did you check your bov connection? The bov's top nipple is connected to the hose that leads to the intake manifold?
....hmmmm....
the intake to actuator is on top and compressor(turbo)/ wastegate to actuator is on the bottom.
Your bov is connected to your intake and everything is tighten well and everything...
The actuator's plug is plugged in...
your bov is venting to the atmosphere well...
Drive around for a bit. When I installed my MBC, I was at 15psi for a bit then it corrected itself. That and your hose maybe cramped or pinched somewhere.
That's all I could think of. Without seeing how it's connected, I can't really figure that out.
....hmmmm....
#52
I did not try leaving the 2 hoses off the bov. Right now they're tapped into the line comin from turbo/wastegate. The intake is plugged into top of actuator and turbo wastegate on bottom. Bov is plugged into intake not vta. Bov is connected to manifold. Ill just try reseting the ecu for about 20min this time and check all connections. I did 1 thing sort of ghetto cuz my intake didn't have a nipple for me to plug the vac line into, just had a vac line size hole. So I just shoved the line in there and used a glue gun to make sure it doesn't come out and so far it hasnt even at wot. I will try drivin it around for few days. Could u diagram what u were talking about earlier....about makin the bov respond better... For future ref
#55
What exactly do u want a picture of so I can take it. Anyways...another question...does it matter which way u put the compressor pill? It might be in backwards. That's all I can think of that could be limiting boost
#56
#59
Ok I took my stuff apart..and instead of tapping the bov into the turbo/wastegate line, I ran it into the intake to actuator line. I reversed the direction of the compressor pill and pushed the pill more toward the compressor nipple instead of the T, but the pill isn't in contact with the compressor nipple.
bishiboy
16
Nov 9, 2004 05:19 PM
