Question: on Boost/Vacuum gauge
Old Jan 5, 2005, 06:42 PM
FuelsResearch's Avatar
the fuel press reg. is ok, it sees both boost and vacuum, the line to the bov should work too. I had an autometer guage and it wouldn't show boost over 10 psi, had to send it back for a new one. You can check for leaks but if your boost is showing normal numbers then I would think about sending it back to them.
Old Jan 5, 2005, 06:48 PM
VenomEVO8's Avatar
First Pic- you can see I tap the line there.. but not from the post on the Defi gauge install?? So do you think I just have a leak.. or should i tap the other line???
Old Jan 5, 2005, 06:52 PM
VenomEVO8's Avatar
just sent back a gauge to Jeg's today.. I have auto Meter Cobalt Electronic... I see boost but no vacuum and sometimes 1 psi boost..
Old Jan 5, 2005, 07:04 PM
That line will work. Is electronic sender wired up correctly. I have a manual guage so there is less to the install.
Old Jan 5, 2005, 07:16 PM
93civEJ1's Avatar
actually i think you should use the line before the fuel pressure solenoid coming directly off the intake mani.
Old Jan 5, 2005, 08:05 PM
VenomEVO8's Avatar
its just plug n play.. don't have to wire nothing up but two 12 volt power and ground
Old Jan 5, 2005, 09:07 PM
Jakeg97's Avatar
install it here !
https://www.evolutionm.net/forums/sh...+gauge+install
Old Jan 6, 2005, 05:02 PM
VenomEVO8's Avatar
Originally Posted by burningmoney97
ya i used that as a reference.. did help alot.. but just used a different vacuum line.. Ill call JEGS tomorrow and see if they have any ideas
