Question: on Boost/Vacuum gauge
Old Jan 2, 2005, 04:27 PM
VenomEVO8's Avatar
I just installed a Auto Meter Cobalt gauge.. What is your Vacuum when at Idle?? I get like 3.. but it the boost is fine.. Im stumped on this one..
PLEASE HELP
Old Jan 3, 2005, 03:55 PM
VenomEVO8's Avatar
:bump: can someone answer this question???
Old Jan 3, 2005, 03:57 PM
bluebanana23's Avatar
1.8 for me
Old Jan 3, 2005, 04:00 PM
donour's Avatar
Units folks, units.
~18 in.hg of vacuum at warm idle (850).
d
Ev0 1's Avatar
I have the Auto Meter CF Boost Gauge and it Vacs at 15-20.
Old Jan 3, 2005, 04:09 PM
tokeone's Avatar
when i was stock i had 15-20 at idle
now i see anywhere from 5-15 at idle.
Old Jan 3, 2005, 04:23 PM
sleet's Avatar
I get about 15-20 at idle..
Old Jan 3, 2005, 05:08 PM
kayyoevo8's Avatar
does your boost stay at 21 psi when you set it at 21? or does it jump back down... mine goes to 21 and then jumps to 15... anyone know why?
Old Jan 3, 2005, 05:10 PM
Jakeg97's Avatar
i take it that you have a boost controller and if so , its installed incorrectly. it should not drop after you set it
Old Jan 3, 2005, 05:12 PM
Jakeg97's Avatar
this is normal - https://www.evolutionm.net/forums/sh...d.php?t=113675
Old Jan 3, 2005, 05:14 PM
Jakeg97's Avatar
boost PSI to BAR converter - https://www.evolutionm.net/forums/sh...d.php?t=114133
Old Jan 3, 2005, 08:08 PM
Smokin Evo's Avatar
i just got that gauge i need to install it
Old Jan 3, 2005, 08:18 PM
FuelsResearch's Avatar
where did you tap the guage to? 15-20 mm HG is normal.
Old Jan 4, 2005, 06:52 PM
VenomEVO8's Avatar
buddy tapped it from the same line he has on his... off the TB.. i must have a leak cause he sees 15-20 in vacuum...ill take pics tomorrow and post..
thanks for the info
Old Jan 5, 2005, 06:37 PM
VenomEVO8's Avatar
i put the t fitting at the fuel pressure regulator??? That line is to the left of the one I saw in another forums bout installing a DEFI gauge.. did I tap the wrong one???
