SC or TT EVO..is it possible?
Originally Posted by Volunteer
wOW.. That sounds like a serious car. Any pics for those of us salivating at the thought of it.
how would you have the car switch from the super charger to the tubo? you couldnt run the turbo intake charge through the super charger, that would be like running one amp into another and defeat the purpose of the turbo.in order to get the high rmp efficiency gain from the turbo you would have to take away the coefficient drag loss of the supercharger witch would need some kind of ratcheting pully. i dont think that the low end gain would be worth the work of sorting all these problems out. true the delta s4 was both super and turbo charged but it was by no means the most powerfull car in b class. the ford rs 200 was making over 600 hp out of 2.1 liters with its single turbo. while the delta was around 460 with its set up.
Originally Posted by 3240
All problems have been sorted out. Wait and see. The car should be running by early June. The supercharger is a one off design that is being custom built specifically for this application.
im veary curouse to see how you did it. that will be awsome if you get the numbers you hope for. good luck with the car and post as soon as you get it done
