4 or 5 Qts for an oil change
Originally Posted by fre
I bet there are some people out there that just fill it up and check it without turning the car on before topping it off just to check their levels a few weeks later and think they are burning oil, when they never filled it up properly in the first place.
That's definitely true.
But my method is actually similar to yours. I pour in 4.5 qts. Turn on the engine to check for any leaks, let it idle for a couple of minutes, then shut her down. After about 5 mins, I check the oil level.
I'm worried about people who check the oil right after shutting down. That doesn't give you an accurate reading. Perhaps I read your post wrong.
No I just only run it for a few seconds. That isn't enough time to really draw a lot of oil away, but just enough to pressurize the system and get it into the other spots that it might settle. I don't let it sit. I am about to go check my level again (just did an oil change). I will see where it is. Last time I checked it was right at the cut where it tapers in on the dip stick.
Originally Posted by evolveMR
i generally fill from 4.6-5.0. a little overfill isnt gonna hurt anything. you SHOULD run your engine for a few seconds and let the oil cycle through the filter, because the filter DOES hold about .5 or so qts.
remember that the amount of oil that will be required will depend on if you're doing a hot or cold oil change. ideally, when you first remove the filter and drain the oil from the pan, the engine should be dead cold, like in the morning or something, so that all the oil will drain. this will require more on the side of 5 qts. however, if you do a hot change, then you will not be able to drain the last bit of oil, and you will side more with the 4.5 or so qts.
benny
benny
The_X_Effect
Midwest Region
Apr 10, 2016 07:44 PM
WTB[Northwest]: 5 speed transmission
djelliott978
Jan 19, 2016 04:03 PM
