Got problem with my e4
Does the original ECU have any cut off system? I accidently slipped a wire from the positive terminal of the battery to the negative terminal. Some spark develop and the next thing i know theres no electrical power whatsoever, i checked all the fuses and battery, its still ok. Anyone has any views?
Thanks
Thanks
Knowledge of the E4 is thin on the ground here. The Evo VIII is the first Evo in the US.
That being said, electronics don't take voltage spikes and shorts very well. I believe there is a fuse that is inline with the main voltage cable on most cars. (not sure on the E4 though) Did you check this one?
I'm still tracing the voltage line but so far almost all the affected areas that i'm presuming have been checked like Battery fuses and ignitions. Will look into it further once i get back from work. Just wondering whether E8 have any cut offs switches, its purpose should be almost similar from E4 above.
Thanks for the feedback.
