622 Whp on 93 octane pump gas with Alcohol injection kit !
Old Feb 9, 2005, 03:26 PM
  #31
Kuba23's Avatar
Whats next u gonna put a Stroker in that b!atch ?? what u goin for 1000 WHP lol ??
Old Feb 9, 2005, 03:31 PM
  #32
Iceman2011's Avatar
600+ whp on pump gas . hats off to AL, great numbers.
Old Feb 9, 2005, 04:17 PM
  #33
DynoFlash's Avatar
Originally Posted by Kuba23
I am scared to ask but how much TORQE ?? loll did u take a vid ??
I dont know hos much tq - I still have not figured how to hook the tach signal to the coil on plug ignition
Old Feb 9, 2005, 04:25 PM
  #34
Quickshift's Avatar
No inductive rpm pickup on there dyno?
Old Feb 9, 2005, 05:17 PM
  #35
Fourdoor's Avatar
Your torque peak is probably right where that power spike on the dyno was at. What RPM are you running at 63 mph in the gear you used on the dyno? You can convert every point on that HP graph to it's corresponding torque as long as you know the RPM and HP at any given point. Just do a nice gental run in the gear you used on the dyno and figure out the speeds for all the normal RPM points (2500, 3000, 3500 etc) and I can calculate up a torque curve for you
Keith
Old Feb 9, 2005, 05:24 PM
  #36
Mistasparkle's Avatar
hey al what are the mods on your car so far?
and do you suggest an alky injection kit or water injection kit for most power
Old Feb 9, 2005, 05:39 PM
  #37
BadazzCR's Avatar
Use both the primary and secondary inductive pick-ups connected to the one ground wire on the coils. Under the make run screen hit Control E and set it so that it fires every 360 degrees. That should work, it has for me atleast.
Old Feb 9, 2005, 06:23 PM
  #38
smp3000's Avatar
Hot Damn! I want to see a vid!!! Are you going to run it at the track before you go back to the drawing board and start ripping out parts?
Old Feb 9, 2005, 06:30 PM
  #39
qbbraveheart's Avatar
thats insane
good job
Old Feb 9, 2005, 06:54 PM
  #40
yesevo's Avatar
is 600whp car faster than bike?
if u wanna feel the power just get bike =cheapest way to enjoy speed.
i wanna feel the power !
Old Feb 9, 2005, 07:27 PM
  #41
DynoFlash's Avatar
I never drove a bike this fast and I have driven some fast ones
Old Feb 9, 2005, 11:54 PM
  #42
Yaroslav's Avatar
Question
Man did you drive R1?
If yes, can you compare your evo and R1?
Which is faster?
Old Feb 10, 2005, 08:11 AM
  #43
Crazy4Cars's Avatar
Which is faster?
Old Feb 10, 2005, 08:18 AM
  #44
Yaroslav's Avatar
Exclamation
Originally Posted by Crazy4Cars
You crapy monkey what do you want?
You looks like virus for my PC
Old Feb 10, 2005, 08:52 AM
  #45
Crazy4Cars's Avatar
Quick Reply: 622 Whp on 93 octane pump gas with Alcohol injection kit !
