Helix Stainless 02 Housing Turbo Outlet -- Easy or a pain to install???
All right guys, I have a delima.....
I have a buddy that will hook me up with a new Helix O2 turbo housing, but I am under the gun for time. I work like a slave (60+hrs/week) and I am pretty sure I am going to Ohio for a custom flash by big Al and Dave Buschur on Sat.
Here is the deal...I am willing to give up some sleep to swap my cat for a Helix High Flow (it comes tomorrow and takes 20min to do), but can I swap out the O2 housing fast too???
Is this a simple install or a real pain in the ****??? I will have the downpipe, cat and catback off anyway, but with 20k on the odo, I think the heat cycling of the stock bolts on the stock O2 housing are going to be a beotch. I am afraid of breaking a bolt and missing my opportunity to get the flash from some of the best guys in the biz.
Advice, tips, suggestions, P L E A S E !
well depends on how comfortable you are with installing things on your car, i don't see it being that hard, many say they take out the manifold and such, but i am sure you can get it on there by taking off the dp and just reaching up and around... i believe there is an install on here, SOOOO good luck.. but in my opinion i dont' think it will be that hard
times always a factor, but just make sure you set aside a good 2-3 hour time period i'm sure you can get it done then. dont' rush cause thats when it takes 2x more then what it should be... i believe you can def take it off wtihout removing the manifold and ****, i looked up there when changing my oil cause i plan to do that mod in the summer... Good luck keep us posted
Dude I just finish installing my helix down pipe and turbo outlet housing. The DP was easy the outlet housing a big pain in the ***. It will easily take you a couple of hours to do it all. My 2 cents.
Originally Posted by bluebanana23
i hear it's a two hour install, easier if you remove the radiator and turbo, and the main thing is to soak the bolts with wd-40
I can do without the sleep, so time is only part of the problem.
What works for a safe install (ie brackets, heat shields) what needs to be removed and/or kept?
I don't think I will be doing this mod right now if I have to take off the manifold, turbo, radiator, or anything else major.
I am hoping that it can be done in a reasonable amount of time (2-4hrs) with minimal chance for damage to the car. Remember, the car has to make a road trip to Buschur Racing in OH for a Sat appointment with big Al and Dave......
The biggest pain in the *** one is the bottom nut right underneath the bend from the tubing. I had to customize the square head of a open wrench to make it work because with the radiator in the way you dont have much room to work with. But the good thing is once you loosen those two nuts its smooth sailling after that. Just put everything back together.
Well the original heat shield to the outlet is gone when the new 02 housing goes in and thats really all but the problems lies with two bolts or lug nuts actually. The first one that is going to give you the problem is the one closest to the engine block. You really cant see it from the top of the car only from the bottom. To get that one nut off you are going to need a long extension, a size 14mm short socket, a knuckle, and a socket wrench.
Thanks for your posts...if you think of anything else, please post away.
I am gonna do the install Friday night, 12 hours before I have to be in Ohio...
I am feelin it. Looks like it's gonna happen, then.
I installed mine without taking the turbo or the radiator out... but I would suggest taking the radiator out cause I jacked mine all up trying to get the damn heatshield out. Install should be around 1-2 hours like everyone said. just make sure you clean the treads before reinstalling the bolts and go slowly. I cross threaded mine and had to cut washers and put them around the bolt and tighten as hard as I could with out snapping the bolt just so I could get it to seal around my turbo
