Suggestion on gear oils?
Old Feb 17, 2005 | 02:57 PM
RalliArtEvoVIII's Avatar
Ok i got a fresh TC ready to be installed in place of my whining, howling, weird noise making TC. Its been howling since like jan-feb-04. anywyas, it ws running stock gear oils at the time, i changed it with redline heavy shockproof 75w90 about 4 months ago. I dont like redline. just hearing bad things about it and etc... well if anyoen else has opinions on what oil i should use for the TC would help!
BTW: if i separate the TC from tranny, will tranny fluid pour out cuz i heard tranny fluid is fed into the TC through a certain area. i plan to drain my TC before i take it off.
Very important: where to purchase the gear oil ur suggesting would help, thanks!
Old Feb 17, 2005 | 03:07 PM
hkfeet's Avatar
I recently did a search and everyone seems to have their own opinion on whats good for their car. AMS put in redline in my tc and I trust them but this has no solved my issues with the whining and howling noises. Maybe you should do a search and go with what you think will work best. You could always flush it and change to a different oil anyways.
BTW: your so lucky to have a spare tc. Im wondering if my ring and pinion gear set is fucted and creating the noises I am experiencing..
Old Feb 17, 2005 | 03:30 PM
i just worked out a deal w/ someone as a trade, so i didnt pay any cash for the TC. im receiving it today. so glad i can get rid of the whining noises!!! so glad. anyways...if ur interested i might be able to get another TC which was used for about 5k miles in a month or 2. PM me if interested.
Old Feb 17, 2005 | 03:36 PM
DaWorstPlaya's Avatar
Stock ....
Old Feb 17, 2005 | 03:37 PM
justchil's Avatar
Man I just use the OEM Diaqueen SAE90w or whatever it is in the TC. It seems to kind of break down after a while but I'm now changing it around every 5000-7000 miles. I think TME or TRE (whatever they are called) recommends this.
As long as u don't mind the smell it's fairly easy to change. You dont even really need a pump if the oil is warm when putting it in. If you to decide to go with the oem stuff there are a few places online u can order it from. I think even lancershop.com has it now.
Old Feb 17, 2005 | 03:44 PM
i just chcked lancershop. $50. I dont think i'll be spending that much. Before, i bought 5 bottles of Redline gear oils, 2 for TC, and 3 for tranny and that ran me around 44 bux. anyoen else suggest anything besides OEM?
Old Feb 17, 2005 | 03:46 PM
justchil's Avatar
It's 5qt for 50.. the transfer takes like .58qt I believe.. so you could change it almost 10 times
Old Feb 17, 2005 | 03:53 PM
Ookami's Avatar
Use only Diaqueen LSD Gearoil unless you want to buy another transfer case, simple as that.
Old Feb 17, 2005 | 04:13 PM
hkfeet's Avatar
I would be interested, plz lemme know when its available
Old Feb 18, 2005 | 05:30 PM
will do hkfeet....btw: no one else sells less quarts of Diaqueen? i dont wanna buy that right now.
Old Feb 25, 2005 | 02:49 PM
megatron's Avatar
lancershop sells a jug of OEM fluid. is that jug enough to change the fluid in my transfer case? is there any other fluid besides in the tc that i should replace to try and get rid of the whining?
Old Feb 25, 2005 | 02:56 PM
k.lowe's Avatar
you cant go wrong with redline
Old Feb 25, 2005 | 03:02 PM
justchil's Avatar
That jug from lancershop is plenty to change the transfer and rear diff many many times. It's 5quarts and the rear diff and transfer together take around a quart.
I think you can go wrong with redline.. ask around
Old Feb 25, 2005 | 03:04 PM
matt55's Avatar
Thanks I was looking for this on line , just ordered from them
Old Feb 25, 2005 | 03:43 PM
V8 HUNTR's Avatar
GM Syncromesh...... its the ****
