Forge VTA BOV owners...spring question
ok i am bout to get a forge VTA BOV, switchin over from HKS SSQ. anyways, ive been readin a lot about the springs and tension, well i am gonna experiment with diff springs, just the yellow and green. im gonna start off w/ the yellow. anyways, i heard there are shims too? how many are there? how many should i put wit the yellow and green spring? thanks, i just dont wanna spend 4 days tryna figure out the spring/shim combo. im runin MBC at 20psi
really? so all these threads i was reading about green/yellow springs for the forge recirc one then huh? ok thanks...so blue with 1 shim is a good starting point? does it flutter under low rpms?
I used the yellow with 2 shims. Seems to work fine for me. Never stalled once in 18k miles, but every once in GREAT while it will drop about 200 rpms but never stalled.
However it does flutter at low partial throttle boost when you let off the gas. But not any more than with the stock DV.
With the yellow spring and 2 shims the spring rate is almost the same as the stock DV. IMO
i was running the forge vta... i had some minor problems with the blue spring stalling. I switched to the dual port turbosmart bov and it is working great. Had it on for 3 weeks now with no problems. The sound is not as loud as the forge but it sounds nice and best of all no stalling.
my 2 cents
my 2 cents
Soon2BEVO
May 24, 2005 04:04 AM
