4g63t and 4g63
Originally Posted by SilverEvo8owner
4g63 (turbo)
420A non turbo
420A non turbo
yes in the 1g there are the 4g63 non turbo and the 4g63 turbo engines. looks the same minus obviously turbo stuff. compression is different, cams different, and obvious stuff that only turbo cars have. 2g has the 4g63 turbo only. there is the 4g64 which is the closest to it which is just a SOHC engine with a .4 lt of extra displacement (same cast iron block). people use the cranks out of it to use for cheap stroker kits.
