How can Vishnu get 390HP with very few mods when the FQ-400 takes all of these...
#31
FQ400 Vs Vishnu tune
I think you're correct in that Vishnu must be getting high performance the easiest way it can and probably at the cost of reliability and the FQ-400 is modded correctly with all the propper beefed up components so as to be a high performance car and also have reliability. Vishnu = Quick Fix FQ-400= Propper Moddification. You're probably right that the FQ-400 is conservatively tuned and why not, if you can get a conservative 400hp instead of a stressed out 400hp then you're doing it right.
I wish I was wrong, I would love to spend $2700.00 and get a reliable 390hp car. I still like the Vishnu stuff but I won't do it without beefing up everything else. I like the idea of Ti con rods and forged pistons anyway...overkill is better than underkill.
And trust me, Exede is no match for a MOTEC.
#32
So its a matter of why they chose the route they did to make the amount they aimed for. I dont know all the factors they were dealing with in terms of contracts, price points, emissions, laws, warrenty forecasting and profit. It can be done with a few bolt ons or full stand alones and digging into the block. (some would say digging into the block to replace an already wonderful and capable rotating assembly is riskier than just about anything)
As far as the Xede is nothing to a Motec well the fact is the Motec is absolutely not needed and combined with the factory ECUs failsafes There was no reason to use it except to passlock it for no additional tuning. They coulda passlocked the Xede also but not taken away the reflash tuners.
#33
#35
Curve area, basic math. Taken from a magazine I even despise.
http://www.sportcompactcarweb.com/ed..._technobabble/
To top it off, from Shiv himself,
link
Finally - I would really like it if you would post up your dyno sheet a bear number means NOTHING - its the curve that counts and the area under the curve
#37
Originally Posted by IE Evo
Tuned pig rich like most factory cars. No race gas map.
#38
Originally Posted by DeZaVu
and i believe Clarkson also mentioned something in the ballpark of 4 miles per gallon... miles or kilos, that's still nothing! that's like, filling up just so you can go driving around looking for the next gas station!
(T_T)
#39
#40
Honestly, I think spending money on building the motor at this stage would be a complete waste of time and money. If you start getting into the area of an aftermarket turbo and big hp numbers...then I'd agree with what you are saying.
#42
i swore he said "4 miles to the gallon"... and they wouldn't say miles, because they use kilometers...
if not, then i suppose...
#43
You're not crazy, I just watched the vid...he did say gallons and miles as the units of measurement.
#45
