All Part Number Request Go Here
#2701
I recently ran over a tire tread ripped off from an 18wheeler...
It came off right in front of me and luckily I was able to avoid most of it.. however it went under the driver side tire and ripped up a couple pieces. I am not exactly how to explain the pieces and I am in the middle of moving so my camera is packed away in storage.
However, I was hoping I could give enough details to get to the point, and someone could help me out so I could find some replacement parts.. hopefully from someone parting out their old car because I'd really rather not pay for these parts to be replaced new.
So the first one is in the wheel well itself. It is the front plastic part of the wheel well. It's held on by the plastic screws that are self locking.
The other one I found in this list already I am just not sure since the piece has more info then the list...
The list says... MN126981 PANEL UNDERCOVER FRONT
The piece says... Panel Under Cover Side LH.
I assume these are the same.
The second piece doesn't seem to be messed up at all and I am not sure I need to replace it.. but it's no longer attached. Is there an easy way to see a picture of the parts for me to make sure?
Oh also I need the part number for the little black 'screw type' fastners that hold all this stuff on. I saw someone else ask this but wasn't clear on the part number from any of the responses.
#2702
Is there a part number for the crossover tubes in the front brakes? I got screwed on a front caliper deal and now i don't care about cosmetics i just want a non-damaged crossover tube.
#2704
question in regards to the type of gear lubricant that should be used on my evo ix gsr 5speed. I'm not sure why mitsu would give the 5-speed to need a GL-3 sae 75w-80 were as the evo ix MR takes GL-4 sae 75w-85. I'm confused. I can't seem to find the GL-3 anywhere. can you shed some light on the subject? do you know why they use different gear lubricant ratings? I need to order some stuff but I want to make I order all the rightful components for my car.
Thank you.
Thank you.
#2706
#2709
Thank you.
Thank you.
As for your tranny fluid, the crappy thing thru Mitsu, is you can only order 5 gallon pales of it, so alot of people just generally go with Red Line, or something along those lines.
Nothing really. It is just a supersession. MR552951 was the old part number, Mitsu just changed it to the MZ690193.
