All Part Number Request Go Here
#272
Originally Posted by OZLancerlunitic
I need for a 2002 US LANCER OZ
1. Front Oxygen Sensor
2. Rear Oxygen Sensor
3. Hole Plug(see pic 3)
4. Plastic Tabs that go in door handles(see pic 2)
5. Plastic Trim Ring for Passenger Side Rear Door Handle
6. Air Intake Ram Air Piece(looks like 2 nostrils, cant take a pic cause I dont have it )
Parts off an Evo that I need:
1. Fog Light Harness
Thanks a ton
Thanks a ton
#273
Bump, thanks JustDSM.
IE: CS6A, CK5A, ect?
I need to know that in order to help you out.
#275
Let me know that, and which "classification"
IE: Sport 5spd, L-Line 5spd, ect ect.
I'm not familiar enough with your car to get you the right parts, so I want to make sure I'm looking at the correct stuff.
#277
1. Front Oxygen Sensor MR578634
2. Rear Oxygen Sensor MR507854
3. Hole Plug(see pic 3) MR795453
4. Plastic Tabs that go in door handles(see pic 2) Left: MR573539 Right: MR573544
5. Plastic Trim Ring for Passenger Side Rear Door Handle MR627179
6. Air Intake Ram Air Piece(looks like 2 nostrils, cant take a pic cause I dont have it ) MR497518
1. Fog Light Harness As mentioned above, this is part of the main vehicle wiring harness. It is not a simple swap. I suggest wiring it yourself.
Thanks a ton
Thanks a ton
#279
......im in Boston, MA. are you SURE its a california model?
SRHEL7M SPORT (MPI),4FA/T CAL 40E
Thats a California model.
#282
Originally Posted by JustDSM
I can't answer that.. Perhaps your dealer ordered the CA emmissions package. That's the best answer I can give you.
I did check the VIN I used. It is what you provided.
a little but any idea of the difference? Thats sad knowing i have a CA emission cars.....too bad cause all the cats are out anyway
#285
JustDSM,
Can I get a part number for the front bumper of a rally red evo? Also, do you happen to know if the painted replacement bumper comes with all the mesh grills installed or are those separate pieces? I need the mesh that's in front of the intercooler + the upper and lower metal frame rails that it bolts on to. Lastly, I need the stock lower
lip piece in the same color (or does that come with the bumper as well?).
Thanks a bunch.
EDIT:
I just browsed through the parts list and saw the PN's for the mesh grill and the front air dam lip. So I guess my question really is what is the part number for a rally red front bumper and what comes with it (air dam lip? any mesh grills?)? I hit a freaking raccon and need to get this stuff fixed. Thanks!
Thanks a bunch.
EDIT:
