All Part Number Request Go Here
#2897
NEVERMIND - Part Number is MB109960
Looking for the part number of the *STRUT CAP* (2006 EVO).
it's a little black plastic cap which that plugs into the front strut top hat to make sure dust doesn't get in and affect the top hat bearings.
It's the ITEM NUMBER #1 on the picture below.
#2898
heres some part #'s:
MN126523 Front bumper
MN126770 Front bumper cover upper support
MN126774 Front bumper lower right grille
MN126516 Right air intake duct
MN175822 Front bumper brace
MN150612 Right radiator side panel
MR464612 Radiator
8301A466 Halogen headlamp assembly
MR571600 Intercooler pipe (part of lower)
MR571601 Intercooler pipe (part of lower)
MR554844 Oil cooler pump
MR957467 Windshield washer resevoir
MR245368 Windshield washer pump
MN161048 Rocker panel
MR954198 Right rocker panel deflector
MR464612 Radiator
#2899
hey, what would the part numbers be for the exhaust brackets and rubber grommet hangers that are in the back that hold the muffler in place. there are two that bolt to the car. I had the HKS exhaust and it came with it's own hangers/brackets, I now switched to the Buschur exhaust and I need the stock ones back. also, whats the part number for the rubber grommet hangers and bolts that goes through the grommet hangers that the stock downpipe uses.
please post if ya know
thanks,
John
thanks,
John
#2900
John, the Buschur exhaust will come with the hardware your need for install. Regarding the hangers, go to Kartboy.com and get the upgraded hanger set. Helps to stop movement of the exhaust a little more, stiffer mounts.
#2903
John, you are correct the Buschur exhaust uses the stock mounts with new hardware to connect to the rubber mounts. Call or email Jarrod at Buschur and he can send you a whole new hardware kit. The Downpipe uses non-stock bolts, as well.
#2904
thanks,
John
thanks,
John
Here is a link for all the hangers, bolts and washers. I was unable to locate any brackets on the body side. Were they welded in?
http://www.mitsubishiparts.net/cart/...0*3+MF243660*2
#2905
#2906
hello,
looking for a fuel pressure regulator, Evo 8 2003.
Aslo anyone know how much IAC goes for aprrox?
Thank you.
Thank you.
