All Part Number Request Go Here
#2957
#2959
i'm getting this adapter to put my water temp sensor in: http://store.42draftdesigns.com/Lanc...ptor_p_56.html
is there any kind of gasket that goes inbetween that and the thermostat housing???
if so, I need that part number, didnt see it anywhere.
also, I need the part number for the lower radiator hose.
thanks,
John
thanks,
John
#2960
I'm actually looking for the part number or the actual bulb number that is for the Check Engine Light. Mine has been on for so long, it finally burned out. I'd like to go pick one up and only have to pull apart my dash once just to replace it instead of pulling it apart, taking the bulb out to see which bulb it is, then putting it back together to go get the bulb, only to pull it apart again to put the new bulb in then put it back together.
#2961
http://www.mitsubishiparts.net/cart/?id=571&pn=MN119785
#2962
thanks,
John
thanks,
John
http://www.mitsubishiparts.net/cart/?id=571&pn=MN135593
#2963
LINK
http://www.mitsubishiparts.net/cart/?id=571&pn=MB444536
#2970
not worth ordering oem ones...I ordered mine from works. the package includes two new shaft seals and the OEM gasket between the throttle body and intake manifold. For a part that is so susceptible to wear and mitsubishi doesnt even have them as part of a service. its a crucial spot that developes huge boost leaks. my $.02
