All Part Number Request Go Here
Old Jan 2, 2005, 09:10 PM
  #316
JustDSM's Avatar
Originally Posted by lacartus
JustDSM, is there a part # for the '05 fog lights? Would it be a part # for just the fog light or the entire housing that includes a fog light, hi-beam, and HID lo-beam?
Thanks! Ian
So you're asking for the headlight housing?
Old Jan 3, 2005, 05:02 AM
  #317
lacartus's Avatar
Ideally I'd like a part # for just the fog light (reflector, bulb housing) that is inserted into the overall headlight housing. Hopefully it has a part # that is separate from the part # of the overall light housing (lo-beam, fog light and hi-beam.) Thanks!
Old Jan 3, 2005, 02:48 PM
  #318
spoolingEVOx's Avatar
can someone please post the part number for the following piece as soon as possible:
Lightning Yellow front airdam lip
thanks!!
Old Jan 3, 2005, 08:01 PM
  #319
JustDSM's Avatar
Try MS820976
Old Jan 3, 2005, 08:05 PM
  #320
JustDSM's Avatar
thanks!!
Check the posts I've made recently. It's likely you'll only be able to get the white one rather than the pre-painted. Part number has already been posted in this thread.
Old Jan 3, 2005, 08:07 PM
  #321
believe it or not, ive sifted through this whole thread (an incredible post, i should add) and gave that particular number to my dealer as well as input it into mitsubishiparts.net and came up with negative results..
Old Jan 3, 2005, 08:12 PM
  #322
the part you listed with the suffix HC described on mitsubishiparts.net as:
Panel+air Dam Ski and costs about $176.. is that the right piece?
Old Jan 3, 2005, 08:55 PM
  #323
SilverCOEvo's Avatar
I just went through the whole thread, and I apologize if I overlooked...
driver's side a-pillar (03 Evo)?
Thanks in advance.
Old Jan 3, 2005, 11:39 PM
  #324
JustDSM's Avatar
Alright... Mitsubishi is obviously phasing out the part numbers for the pre-painted parts. All the color codes tacked on at the end of the P/N are no longer valid.
MN126784WA
The above is now the correct part number for the front air damn. This piece will come white. I hope this helps.
***NOTE***
Any part numbers I've previously quoted as being pre-painted will likely no longer be valid. They will need the BA, HB, XA, YA, ect suffix replaced with WA in order to get a valid part number.
Example: MN123456BA would not work. You would need to use MN123456WA instead.
Old Jan 3, 2005, 11:46 PM
  #325
JustDSM's Avatar
Thanks in advance.
MR631941
Old Jan 4, 2005, 07:20 AM
  #326
Thanks
Old Jan 9, 2005, 10:21 AM
  #327
hkfeet's Avatar
Need part #'s for the those plastic push tab clips/screws that is found to secure the stock intake box, and trunk interior lining. Lost a couple
Also need part #'s for the rear trunk panel tabs/screws with no push tabs, just big round tabs. The rear trunk panel has 4 of them to secure it down. Broke a few of those as well.
Old Jan 9, 2005, 10:50 AM
  #328
OZLancerlunatic's Avatar
I dont reccomend buying those at the dealer, at the auto parts stores you can buys a big box of them for a couple bux. I think it comes with like 20 of them.
Old Jan 9, 2005, 11:20 AM
  #329
hkfeet's Avatar
Thanks for the advice. I'll go check a few stores by my house
Old Jan 10, 2005, 05:22 AM
  #330
sillypuddy's Avatar
the aftermarket plugs are universal fit, get the mitsubishi part instead, i think i paid like $0.50 each or somethign.. cheap
-joe
Quick Reply: All Part Number Request Go Here
