All Part Number Request Go Here
Old Aug 31, 2011, 02:18 PM
  #3571
97 dsm 4g63's Avatar
I need part number to the tiny bulb inside the hazard light switch for evo ix?
Old Sep 1, 2011, 10:28 AM
  #3572
Plat Vendor
RussellM's Avatar
Please Follow the Link Below
http://www.mitsubishiparts.net/cart/?id=571&pn=MR572769
Old Sep 3, 2011, 04:22 PM
  #3573
73DatsunZ's Avatar
Does anyone know the part number for the Evolution MR badge that goes by the shifter?
Old Sep 4, 2011, 06:11 AM
  #3574
Plat Vendor
RussellM's Avatar
http://www.mitsubishiparts.net/cart/?id=571&pn=8011A017
Old Sep 4, 2011, 11:41 AM
  #3575
73DatsunZ's Avatar
Thank you sir!
Old Sep 11, 2011, 09:36 PM
  #3576
EvoDan2004's Avatar
anyone have a part number for a 2004 evo RS ''RS only'' engine harness. this is the one without abs.
Old Sep 20, 2011, 10:42 PM
  #3577
alishaz's Avatar
hi can anyone tell me the parts number for the black plastic piece which shields the left and right headlights beneath the front bumper cover?
also for the front hood latch.
thanks!
Old Sep 21, 2011, 12:03 PM
  #3578
Rex915's Avatar
Hey bud, do you have the seal on the tranfercase between the transmission, as well as the two front axle seals? Thanks in advance for your time.
Old Sep 21, 2011, 12:06 PM
  #3579
Rex915's Avatar
O yea ^^^^^^^^ this is for an evo 8
Old Sep 24, 2011, 01:59 PM
  #3580
rallytrack's Avatar
Fule part numbers
Tank rusted out, 03 EVO VIII, 80,000 miles! Looking for part numbers for the fallowing. I used the discriptions in the OEm manual I down loaded when the car first came out. They do not seam to match the discriptions on any web site.
Fule Tank
leveling valve assembly(located on top of tank next to fill tube)
Shut off valve(lovated on the higest point of the tank, middle back)
Rollover valve assembly(in fill tube bung, check valve)
Fill hose
thanks
Got a used tank that had all the parts.
Old Sep 25, 2011, 05:52 PM
  #3581
HanzGerdan's Avatar
part numbers (or specs/sizes) for the following bulbs needed:
rheostat switch
headlight leveling
hazard
i/c spray
foglight switch
cigarette lighter
ashtray
thanks!
Old Sep 26, 2011, 03:31 PM
  #3582
Schmidty7's Avatar
thanks for the list!
Old Oct 2, 2011, 11:47 AM
  #3583
Papa_Duece's Avatar
Does the drilling template and install instructions come when you order the reverse camera, or is it is separate item?
Old Oct 2, 2011, 01:30 PM
  #3584
Thoe99's Avatar
Can I get the part# for a front wheel hub?
Old Oct 4, 2011, 08:51 PM
  #3585
Wellsfargo's Avatar
I need a part number for the little steering wheel caps for the evo9 steering wheel. If you look at your steering wheel there should be 3 of them on each side. Thanks
Quick Reply: All Part Number Request Go Here
