All Part Number Request Go Here
Old May 10, 2005, 11:09 AM
  #586
twentyone's Avatar
thanks, but i got it from the dealer.
MR286178
labeled: Cylinder, Trunk Lid Lock
Old May 18, 2005, 10:31 AM
  #587
Richard Sierra's Avatar
Originally Posted by JustDSM
Jon,
Do a search under my username in the for sale section. I had assembled the parts for that exact swap, but I ended up going with a GT3076R from AMS instead.
You'll see the title as something like "10.5/TME install kit"
JustDSM,
Please repost the numbers. It looks as though the post is dead after the change in the private for sale forum. Thanks in advance
Old May 18, 2005, 01:13 PM
  #588
JustDSM's Avatar
Exhaust manifold gasket: MR323654
Exhaust manifold washers: MD050076 x2, MD041192 x7
Exhaust manifold nuts: MR224500 x2, MR212302 x7
Turbine housing gasket: MR404547
Exhaust manifold-turbine housing bolt: MN119783 x2
Exhaust manifold-turbine housing washer: MD132933 x9*
Exhaust manifold-turbine housing nut: MD132930 x2
Exhaust manifold-turbine housing stud: MN119784 x2
Turbine housing-O2 housing gasket: MR299686
Turbine housing-O2 housing stud: MR224441 x2
Turbine housing-O2 housing bolt: MD062961 x3
Turbine housing-02 housing nut: MD050073 x2
Compressor outlet gasket: MR281085
Oil feed line crush washer (head): MF660063 x2
Oil feed line crush washer (turbo): MF660064 x2
Oil drain line gasket (turbo): MR258477
Oil drain line gasket (oil pan): MN156738
* These washers are also used on the O2 housing. Order a total of 9 for a complete install, or only 4 if you are not removing the turbine housing.
Old May 19, 2005, 06:51 PM
  #589
evolution mr's Avatar
I am planning to replace my front bumper and get the C-West bumper. I am looking for a part number for the Mitsubishi Symbol that on the EV IX. It's sort of like a floating Mitsubishi Symbol. Do you know the part #?
Old May 19, 2005, 08:01 PM
  #590
timzcat's Avatar
Not until the car is actually released here. Parts are not available.
Old May 20, 2005, 09:49 PM
  #591
dani6785's Avatar
O-ring bearing that goes between the tcase and tranny , need the one that goes around the shaft in between t-case and tranny. Also a Oil Seal for my tcase
Thanks
Old May 21, 2005, 03:59 PM
  #592
SoR
SoR's Avatar
Is there a part # for coolant fluid Mitsubishi uses in Evos?
I almost put Preston dex-cool in my car but decided to do some research first and it's good I did!
Thanks
Old May 21, 2005, 08:03 PM
  #593
justchil's Avatar
I'm using the prestone 50/50.. it works great!
Old May 22, 2005, 06:48 AM
  #594
blakevo8's Avatar
question
i have an 03 evo and i need to know which part number is for the left side A-pillar i dont know which it is.
Old May 22, 2005, 04:04 PM
  #595
evoD's Avatar
looking for part number for non-evo lancer center console. not the piece that goes around the shifter, but the one behind it under the armrest. either the non-Evo Lancer part number or the MR part number please...thanks.
Old May 22, 2005, 07:31 PM
  #596
timzcat's Avatar
MR648664 LH Pillar Trim L-Gray
Old May 22, 2005, 07:44 PM
  #597
timzcat's Avatar
Lancer MR626770 but it is listed as Dark Gray
MR is same part number.
This is the piece below the armrest and contains the cup holder. Doesn't include the rest or the cup holders
Old May 22, 2005, 11:21 PM
  #598
evoD's Avatar
Ok...I'm looking for the cup holders then that dont have the opening for the water spray switch. I've noticed on the non-evo lancer that they have larger cup holders and no opening for the switch, but yet some seem to have a blank for the opening. I'm looking for the one w/o the opening at all...just the cup holders only as on the non-evo lancers. Thanks again.
also...i looked through the list but couldn't find it...cabin air filter part number please?
Old May 22, 2005, 11:58 PM
  #599
timzcat's Avatar
That is it. The cup holder part attaches to the console part from the bottom.
In other words there is just a hole in the console for the cup holder.
MN185231 Air Refresher Assy.
MR633548 Is the cup holder part. Good news is all the consoles are the same which means you can just get the cup holder part if you are eliminating the intercooler switch.
Old May 23, 2005, 11:23 AM
  #600
evoD's Avatar
thank you very much
Quick Reply: All Part Number Request Go Here
