All Part Number Request Go Here
#631
Originally Posted by SS RX7 r2
Hello,
Anyone know the part #s for the rear toe and camber boltsw/ the ecentric cam washers attached?
TIA
TIA
#632
Originally Posted by Nate
Maybe I'm just not finding them, but could you post the number for the Timing Belt and Balance Belt?
I'm wondering if it's the same MD326059 as the rest of the 4g63 engines, or something different.
Thanks.
Nate
Thanks.
Nate
The balance shaft belt is MD182295
MR984778 is listed with it as "RP" which I am assuming is a replacement number.
#634
Originally Posted by Jon H
Looking for the part numbers for the 3 bolts that attach the intercooler sprayer tank to the frame.
Thanks in advance
Thanks in advance
MS240126 8X25 bolt
#635
Originally Posted by timzcat
MS240021 6X16 bolt
MS240126 8X25 bolt
MS240126 8X25 bolt
#636
I agree. I know there are 2 different size bolts but don't remember if they are just larger for the mounting bracket. He should be able to tell if he needs 3 small bolts or a mix.
#645
Justin when you have time can you look up the part #'s for all 4 interior door plastic/suede panels? I want to check the prices so see if I should just get new ones or just have it customized to hide and prevent anymore scratches.
