All Part Number Request Go Here
#961
Originally Posted by justchil
I need the part# for the wheel well plastic on the passenger side.
I found this but it's for the driver side:
2003 lancer evo 8 inner fender wheel well plastic driver side front
MR954175 - Shield Kit, Splash, Front LH
#962
I need the part # for the vacuum hose that goes from the wastegate actuator/turbo outlet(they connect via a T) to the wastegate solenoid (the vacuum hose(s) removed when installing an mbc)
Thanks!
Thanks!
#963
Thanks!
Thanks!
This is interesting, the never assembly uses MN156396
The older part is MN143555
Wonder what the difference is between the two. If you have an 03 then it's the older part.
the statements posted above is what i copied from post #541. i have an 05 and ive used the mn143555. but i guess u can try the mn156396(ive never tried it)
#968
Part # for right side A-pillar (RS) panel
So it's documented, the part number for the Right side (Passenger) A-pillar panel from a RS (no tweeter) is MR644581. I guessed at the number on Mitsubishiparts.net, and was right.
MR644581 04 RS front Right a-pillar panel (no tweeter)
#971
Part # for climate control assembly. It is the white plastic part that is behind the dash bezel below the radio. It has the posts that the knobs slide onto, two plugs on the back, and it connects to the actuator cables for the temp and vent controls.
#972
Originally Posted by bpclements
Anyone have the part number for the entire front case assembly to include the oil pump and gears?
MD351820 Case Assy, Cylinder Block, Fr
This includes the entire front case (oil pump case), oil pump gears (drive and driven gear), and the oil pump case cover.
#974
I'm trying to replace my stock manifold heatshield with a polished Buschur manifold. What are the part numbers for the bolts that hold the heatshield in place? Are there any washers or anything holding the heatshield in place? I can't bring myself to go check right now in the dark of night.
#975
