All Part Number Request Go Here
Old Aug 23, 2006, 05:21 PM
  #1201
Soon2BEVO's Avatar
I need the part numbers for
Timing Belt
Balance Shaft Belt
Timing Belt Idler pulley
Timing Belt Hydraulic Tensioner
I know I need the Timing Belt Tensioner Pulley and the BS Belt Tensioner pulley. For those numbers I have MD369999 and MD352473. I hope those are right!
THANKS!
Old Aug 24, 2006, 10:46 PM
  #1202
MYEVOVIII's Avatar
Okay I have an 03 Evo VIII and am installing the MR gauges in the lower din just like the new MR and RS have them but the gauges I got from another member here did not inlcude the brackets just the lower replacement plastic thing that goes in place of the cubby hole. Any idea on the part number?
Old Aug 25, 2006, 05:53 AM
  #1203
Spins4's Avatar
Originally Posted by 20psiMR
Anyone able to give me more info on these part numbers? They are on my invoice from service, had a 5th gear grind and this is what they are replacing. Im wondering if its pretty much all the internals...
MN132429
MN132403
MN132411
MN132421
MN132407
MN132419
MN132415
VIN is JA3AH86C86UO41800 in case you need it. For MR 6 speed tranny.
Those are all just pretty much seals, rings, and a few near synchros. If I have time later I'll break it all down..but its all the parts Mitsu puts in the TSB for 5th gear grind, and that is what they use to "fix" it.
Old Aug 25, 2006, 05:57 AM
  #1204
Spins4's Avatar
Timing Belt
Balance Shaft Belt
THANKS!
Timing belt: MD326059
Balance belt: MR984778
Idler Pulley: MD369999
Hydrauic tensioner: MR984375
Old Aug 25, 2006, 06:23 AM
  #1205
Spins4's Avatar
Sorry man...can't get those seperate..just got off the phone with Mitsu to confirm that...
Old Aug 25, 2006, 07:54 PM
  #1206
MYEVOVIII's Avatar
thanks anyway for checking I really appreciate it.
Old Aug 26, 2006, 02:39 AM
  #1207
Ev0six's Avatar
Whats the part number to the tie rod end?
Old Aug 26, 2006, 10:58 PM
  #1208
slavsevo8's Avatar
i need a oil cooler
hey, i need a oil cooler
MR464630 Oil cooler
see if you can find one for me...thanks
Old Aug 27, 2006, 10:26 PM
  #1209
Evoisdream's Avatar
looking for the Injector seals to the Intake mani, Not the orings on the injectors to the rail but the thicker biggers rings some reason mine are all hashed.
evoisdream
Old Aug 27, 2006, 10:52 PM
  #1210
timzcat's Avatar
I have 4 barely used that I can Fedex to you for $5.
Only about 5000 miles on them.
Old Aug 28, 2006, 06:29 AM
  #1211
itzwolf's Avatar
Anyone got the part number for the Idle Air Control valve?
EDIT:
Nevermind found what I was looking for, got ahold of my contact @ Mitsu Parts Dept.
2003: MD628318 (This part number has been changed as the part itself has changed. See below)
2004+: 1450A069
Old Sep 1, 2006, 10:59 AM
  #1212
UCB
UCB's Avatar
03 evo HID headlight harness (to run the motors)
And the harness and leveling switch for inside
Do the harnesses come on all evos, just not hooked up for the non-ssl?
Old Sep 8, 2006, 11:11 AM
  #1213
Elu
Elu's Avatar
Just adding a part # since I couldn't locate it on the list and recently bought mine at the dealer.
MR522027 Lamp Assy, Side Turn Signal Light.
Old Sep 8, 2006, 06:56 PM
  #1214
evo8dad's Avatar
I need part numbers of the rear (left and right) upper balljoints. At the control arm where the top portion of the end link attachs.
'03 Evolution
Thanks
Old Sep 9, 2006, 11:10 AM
  #1215
BaLListic_EVO's Avatar
need the PN# for a front passenger side axle seal the seal in the T-case
Quick Reply: All Part Number Request Go Here
