All Part Number Request Go Here
#1351
Originally Posted by M5150
Does anyone know the part # for the front bolt holding the front control arm to the subframe?
TIA,
Max
TIA,
Max
#1352
Hey guys, I've tried to search but to no avail. I'm just looking for the part number for the clips that hold the front lip to the splash guards under the car, they're about the size of a nickel with the screw in/out piece in the middle. Pretty much the same clip that holds every plastic piece together that I've seen. Thanks!
#1353
#1354
Foglamp switch
Searched, but couldn't find this one -- part number for the foglamp switch? Anyone? The switch next to the HID leveling switch, to spell it out!
Thanks,
Mike
Thanks,
Mike
#1356
Originally Posted by HIPSI9
didnt find this one either, i need the black louvered (sp) vent cover that attaches to the underside of the hood. i need this part badly
#1357
Hey guys Im looking to find the plug that plugs into the stock ignition coil. I cut mine off to install my Coil on plug set up and cant find them again, I want to change back to stock. Does mitsu offer pigtail versions of these or do I need to buy an entire harness. If so I guess its off to a junkyard to see if any other mitsu uses one of these 3 pin/3wire connectors.
#1358
Hey guys
I am looking for part numbers for the 4 bolts that hold the hood to the hinges. All the same bolts. And also the OEM J-Panel piece thats next to the side mirrors and the two bolts that hold the rear middle triangular exhaust hanger bushing.
I have had no luck finding any of this off OEM parts. thanks
#1359
Thanks,
Mike
Thanks,
Mike
Mike
#1361
Originally Posted by Blue By You Evo
Hey guys
J-Panel pieces: MR462051 and MR462052
Exhaust bolts: MF243361
#1362
Sorry man...but I don't be seeing any seperate pigtails yet. Only for like the lights and what not.
#1363
anybody?
Mike
Mike
