Oil Pressure
![Unhappy](https://www.evolutionm.net/forums/images/icons/icon9.gif)
i installed a Omori oil pressure gauge and was shocked when the car was warmed up. the oil pressure at idle was below 10psi!??!?!?! what is everyones oil pressure at during idle?? i checked the manual and it states "After engine has warmed up, check that the oil pressure is within the standard value. STANDARD VALUE: at idle-29kPa(4.2psi or more). at 3500 r/min 294-686(43-100psi)
that is shocking once i found the info from my manual CD. 4.2psi or more at idle?!?!?!? crazy. this info can be found on the CD manual in group 12, section 5.
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
Wanchai Panpron
Lancer Engine Tech
Nov 24, 2016 11:34 PM
