help with TT
help with TT
I know its not the install section but im not getting a responce there, so mods im sorry but do what you wish.
Im trying to install my Apexi TT and I have the HKS harness, now where under the dash is the connection the harness plugs into?
ok, now I got everything connected. The O2 and the Ground along with the E-break wire are spliced. The harness is also plugged in. The car runs, however the TT does not turn on, so I dont think there is any power going to it. What could be the problem?
thanks guys, I found the problem. I used clamps to splice the wires and they had not completely spliced the wires. So I took them off and just did it the old fasioned way. Now it works fine. Thanks again for all your help
Ok sorry for a dumb question, but is the o2 connection only used to monitor the a/f. Do I have to hook that up? I already have an a/f guage. All I want is the tt function (I have the apexi tt with the wire harness) So basically can I just hook up the wire harness, e-brake and ground? Thanks.
Yea, it doesn't work to well for a/f readings. I didn't even bother hooking it up to the o2 wire on the ecu. I don't need a/f readings on this or the auto mode feature. Still it works fine as a timer.
