how much whp?
My guess would be around 260WHP on a dyno jet.
Remember when or if you dyno your EVO use the dyno numbers as a baseline, because so many dynos read different. So please don't come back one day asking why your car dynoed so low on a dyno dynamics for example, when those dynos have a history of reading low. Compare your car to what other EVOs have dynoed on the same dyno. So if you dyno at 230WHP on low reading dyno, and your friend dynos at 270WHP on a high reading dyno jet and you guys have the same mods, then don't be like what is wrong with my EVO, when there is nothing wrong with your EVO. Now if he dynoed 40 WHP higher than you on the same dyno, then you might have some problems. Sorry just tired of people complaining about there dyno numbers on a low reading dyno.
Originally Posted by cyberninja
How much whp would you think i have with these mods?
-k&n intake
-3in downpipe
-2.75 cat back exhaust
-hyper grounding kit
-k&n intake
-3in downpipe
i have 264i/272e hks camshafts(no gears) in the attic and a walbro 255 fuel pump. I also have a s-afc2 but i haven't bought the harness yet. If i installed these how much would i be looking at?
Heh, I don't understand how what some people base these threads on... whatever #'s people guess and assume you'd dyno at should have absolutely no relevence to anything. It's like doing a chemistry experiment and just asking your lab partner how many grams of solution will be formed without doing the experiment itself. Your best bet is to go to a dyno day at your local performance shop w/ an awd dyno and pay the $30 or $40 and get a few pulls in. It seems all too common for people to ask these horsepower estimate questions on the internet, then turn around and tell their friends whatever the ppl said.
-k&n intake
-3in downpipe
-k&n intake
-3in downpipe
Originally Posted by ct9a gsr
....Your best bet is to go to a dyno day at your local performance shop w/ an awd dyno and pay the $30 or $40 and get a few pulls in. It seems all too common for people to ask these horsepower estimate questions...
My guess is around 15-25 whp. Like matt said, I wouldn't taper a 3"DP to a 2.5" catback. I'd stay away from the K&N intake too. That grounding kit will not add any power.
Originally Posted by silverEVO8
The exhaust is probably worth around 20 whp. The rest are probably not worth much if any for WHP increase. A typical '03-'04 EVO will put down 216 whp on a DD dyno. With exhaust, maybe 245...... Have you had your car dynoed before the mods?
Originally Posted by matt55
its not a good idea to go from 3'' dp to a 2.75'' cat back ///maybe 15 hp more than stock with that miss matched exhaust combo .
thx for the help. were is that dyno place that you guys mentioned far away from goldsboro. I think that i will buy a megan racing cat back exhaust system tonight with a higher flowing cat.
