New EVO owner! need help!!!
Originally Posted by badhabit90
recheck the lines that go to the turbo outlet and the wastegate actuator. i had the same problem last night with only running 10-12lbs of boost. the tube with a red/orange mark should go to the wastegate actuator. you should get your factory boost reading back. good luck.
hose from the Wastegate is running into inlet (nipple thats in the middle of the BCS) and the other (turbo nipple hose running into the other on the BCS)
the top nipple from the BCS is the one that goes into the intake track after the mass airflow sensor.
it just sounds like he has to get a factory line with the pills in it. but then again, why did he take out the boost controller anyway?? should have just turned the boost down.
the hissing sound may also be a boost leak somewhere once under boost. he needs to also check out the intercooler pipes to see if their may be a leak below-in the bumper area-that he may not know about. cause is sounds like he still has problems even after taking the stuff out. good luck.
Thanks for the great info!
remember! I have injen intake with greddy BOV!
I dont think there is a leak! Maybe I need to drive someone elses evo?
Yeah, the hissing is the chirping noise I hear from the BOV!
when its on WOT, yes it make the hissing noise! its the filter sucking in air!
I heat filter and then I hear turbo! let off gas! I hear BOV!
I got it! all I have to do is, make sure when I get the hose, make sure the red/orange goes into wastegate, other end of the T goes into turbo!
hook the hose up to BCS and outlet to intake nipple!
I guess, I can run off of MBC for now!
wastegate hose kit from the dealer is on backordered!
worst part is that they dont know when it will come in!
I was suppose to recieve it today! Not very happy right now!
good thing for the MBC!
thanks guys!
learned alot from just one problem! you'll be suprise, what you can learn from all these search, googles, how to's , and PM!
But the best answers were all the this forum! Thanks again!!
thanks guys!
Casey Robertson
Jan 29, 2016 03:59 PM
