Does the Evo RS come pre wired for speakers?????
I just baught a New 05 RS a weeks ago and was wondering if I were to bye a stereo would it have to be wired through the car or is it already pre wired and ready to just plug and play. Basically speakers will just plug right in????? Thanks
Yes it is wired for a stereo and it has sun visors, for god's sake. It also has an engine, gearbox, clutch, brakes, 4 wheels and tires, air conditioning and a Lancer Evolution badge on the trunk.
The only things that are missing are the rear wing, ABS, a radio, electric window lifts and door locks, and carpeting in the trunk. The side mirror housings and door handles are black. Otherwise, it is the same as the GSR.
Originally Posted by Mercenary3
The stock wires are good if youre only gonna listen to AM radio. Otherwise with a decent aftermarket sound system youl want nice heavy gauge wires installed anyway.
Another good question, the Evo 8 comes with a factory amplifier, is this true in the RS? or did they run straight wires? If there is an amplifier is there anything special in installing an aftermarket head unit?
This is the reason I'm asking about the visors..
http://www.mitsubishicars.com/MMSA/j...pecs.jsp?t=all
Under comfort & convenience... Visor with Mirrors is not std for RS... I'm guessing
just visor with no mirrors?
What are Assist Grips x3??
Originally Posted by tke_413
Are you serious? The RS comes with the exact same wiring at the GSR. That's why it's PREWIRED, Mitsu doesn't put different wires in... it wouldn't be cost effective. Even the power window/lock wires are already ran in the fronts, all you have to do is get the wiring harness and parts...it plugs right in. For some reason people think the RS comes with nothing when in fact it's all the same, it just doesn't have the rest of the parts for hooking everything up.
And I was exagerating on the AM radio stuff. But at the same time, if someone is going to spend money on an aftermarket system, a lot of times they will buy reasonably good components, to the point where the wires will bring the sound down. My reply was merely to point out that if the poster wanted good sound quality the stock wires should not be used. Im no knocking the RS or anything, so you dont have to be so defensive.
