A Must Read Help!!!!!
Old Apr 1, 2005 | 10:45 AM
  #31
Kuba23's Avatar
wait so what Clutch is the best for 400-500 WHP ???
Old Apr 2, 2005 | 09:03 AM
  #32
ADVANT123's Avatar
Kuba, from all the research I've done on Evo clutches, ACT seems to get the thumbs up for best clutch for money. Many people are happy with the clutch and it seems to be holding 400+whp.
Old Apr 2, 2005 | 12:32 PM
  #33
Sean@Iveytune's Avatar
The exedy clutch isn't good for that application, why even play games, get the $500 ACT and if you use the 6 puck it will hold alot on a budget. Plenty of cars running around with them.
Sean
Old Apr 2, 2005 | 12:34 PM
  #34
Originally Posted by TurbotrixRacing
The center release bearing either goes in or it doesnt. If the clip pops out it will do it when your trying to put the trans in. Now if the throwout bearing snaps in ... thats it, it doesnt pop out. He has 3k miles on it... goes to the track then it decides to pop out .. Dont think so. The bearing is supposed to snap in ..thats what a pull clutch does. .. If its wasnt in .. he would of never been able to drive the car.
Mark
Turbotrix
I have to agree with you here. I don't think it would have gone 3k MILES then mysteriously pop out.
If so maybe it is a defect with the exedy clutch?
I believe the car was launched too high RPm with too long a slip, he overheated the clutch it slipped all the way down the track. As a result it fried the plates and warped everything, which is why he couldn't get into gear.
Common assault, happens all the time with those clutches they floater plates are thin and are not designed to be axposed to that kind of heating.
Sean
