Stock PSI values
yeah, your mechanic is correct, there is a difference, it's actually a bit less than 19 in 1st and second, and the boost taper is more dramatic in 1st and 2nd. 3rd 4th and 5th are all mostly similar, at least, this is how it works on my car, and all the other Evos here
But your sig says you have a VII not an VIII, and I don't know if there's a difference there or not
id say pretty much except 5th( 5th tends to hold boost differently), but every car is slightly different,but with the stock boost taper, if you get a manual boost controller you can get rid of that.
