Loud THUNK/POP on a fast 1-2 shift?
I can make the driveline clunk and clink all day if I want to. Try rolling forward in gear and slowly stop, then put it in reverse and slowly let the clutch out. CLINK! I'm guessing this is the same lash as the hard 1-2 shift. I don't think there is anything wrong, it's just the design of the driveline.
Originally Posted by NOVA EVO
I hear that "clink" sound from time to time...I think it's just driveline lash...nothing to worry about as long as you don't get a constant grinding noise from the TC.
Originally Posted by mdosu
just try it...actually, your car doesn't have to be on...
friend told me after a hard launch and hard shifts up....he realigned it by doing that. I do it all the time after a rough 1-2 shift and really seems to help.
Only problem is, it'll mess up quickly if you shift too hard again.
Originally Posted by sleet
I did it on the way to school today and it seemed to make the shifting a bit more easier when it goes in. What do you mean it will mess up quickly if you shift to hard again tho? After doing this go easy on the shifting?
