HELP!! Where does the vac line go from the boost solonoid?
We are putting the stock intake back on and have most of it back together. The only thing (I think) we need is we have a line from the boost solonoid that mounts on th airbox bracket, that has no home. Any help would be greatly appreciated. TIA!!
The vacume lines go as stated, the sylinoid has two inputs on it. When mounted the input closest to the front of the car take the line from the stock T with the brass pill in it. The line closes battery side goes back into the intake nipple. I releases the extra air it bleads to achieve over wastegate pressure back into the intake.
Hope it helps.
Hope it helps.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
yea like he stated, basically the lower(towards the headlight) port comes from the turbo/wastegate and the upper (nearest toward the back of the bay) connects to the intake, btw: hows the invidia exhaust sound?
Thanks guys, I found it. There was no nipple on my intake so I wasnt sure.
RalliArtEvoVIII, I love the Invidia, I think it sounds sweet but it's not very loud. It's more of a low mean rumble. If you're looking for something loud, this is definately not the exhaust for you.
05-EVO-GSR
Feb 23, 2017 11:57 AM
05-EVO-GSR
Oct 28, 2008 09:32 PM
dryad001
Oct 14, 2005 06:54 PM
