DEFI Gauges + Craighardy Panel owners
Hmm... I have 52mm and had to use a dremel to cut right support bracket for the stock radio. Didn't cut it off completely, just madea 1/2" cut and bet the bracket to make the oil pressure gauge fit. Otherwise it didn't let me close the panel
Mine fit fine. 60mm Defi BF's. The last one on the right is very tight though.
Another note, the stock radio/climate control panel is held in place with some plastic snap in type fasteners. The climate control is screwed onto the stock panel. Since the CH panel doesn't use these fasteners I found an alternate way to hold it in place.
There are 2 long holes at each end of the climate controls. Use a long screw with washers on the backside to bolt down the climate controls to the dash. The CH panel can then be held in place firmly by screwing it into the climate controls.
HTH.
HTH.
I had to do the same thing with the D series gauges.
12WWGSR91
Oct 17, 2016 10:01 AM
WTB[MidWest]: WTB; Looking for a gauge pod and boost gauge & wideband
TxFAkuma
May 11, 2016 06:26 AM
[WTB] Rexpeed gauge dash pod
sheepy77
Apr 25, 2015 12:11 PM
optionimports
May 12, 2004 12:52 PM
