throttle body intake hose
I was on the freeway last night and all of sudden I hear a thud inside the engine compartment and I immediately lost power. I was able to get it onto the shoulder and found out that the big hose going onto the throttle body popped off. I put it back on and limped it to auto zone. i had to stop a couple times when it came off again.
i bought a hose clamp and tightened the hose back on there, but since then it's popped off twice even with the hose completely tightened. has this happened to anyone else? i never noticed what the stock clamp looked like and I can't find it anywhere. is there a special kind of clamp? i'm just using a standard hose clamp on it.
any other things to consider? this is horribly unsafe. it pops off unexpectedly and the engine loses all power..and eventually stalls. fortunately i wasn't in heavy traffic the three times it's happened.
thanks for your help
Yes,
This has happened to several Evo owners, heh. Definitely look into t-bolt clamps. I got mine for much more money from Hose Techniques. Actually replaced all the clamps in the stock IC piping when I put my Samco hoses on.
I've heard that you can use hairspray on the hose to help it hold, but in my case with t-bolt clamps I haven't had a problem (except for the one time I forgot to tighten it sufficiently)...
Good luck,
FB
Good luck,
FB
This happen to me twice. Once on the Bay Bridge. Before I refitted the hose, I applied a thin coating on the outside of the throttle body and slipped on the hose and no problems since. Always use a ratchet. You will never tighten the clamp enought with a screwdriver.
I know this thread is way old, but I'm having the same issue now. Does anyone know what size the clamp needs to be? I've had it happen and limped it home, then it happened after tightening it down with a wrench... So I think the clamp is no good. Any suggestions?
Sounds like a bad clamp. Stock upper or aftermarket? The stock throttle body has a 60mm opening but thick hose so you need a 2.75' or 3't-bolt clamp if you're running the stock hose. That should have enough adjustment to clamp it down tight. Try http://www.siliconeintakes.com/produ...5552a0cbb2b80c
Does anyone know WHY a t-bolt clamp is better than a worm gear clamp? I mean... I've read up and I get that its not open to debate... but I'm looking at pics on the web and I guess I'm just not seeing the physics involved that make the difference?
velocityhead
246
Jun 1, 2018 02:22 PM
Eric Lyublinsky
Sep 14, 2013 12:26 PM
sabastian458
25
May 8, 2013 12:49 PM
