Turbo timer grounding
I just installed my HKS type 1 turbo timer. but i was wondering where other people placed the grounding wire. I attached mine to the screw holding the round ignition wire holder. I'm asking because on my second start up, my ignition fuse blew. Thanks to people who reply
Apex TT, but grounded the wire to pin 26
http://www.roadraceengineering.com/e...-ecuwiring.htm
there is also a bolt into the frame located to the left of the fuse box under the steering wheel. Should work for ya, also you dont need as much wire as you would to go to the ECU like turbolarry suggested.
I replaced the fuse but didnt bother to change the grounding. I grounded to a screw thats just above what this picture shows in the black plastic casing the harness connects to (cant see it in the picture). The screw connects to the steering column (verified with an electric current indicator). This should be fine right?
I'm such a nub.
