Adjust BOV spring?
Adjust BOV spring?
Heard it was a stupid idea. Just want to get some input. I have an "evo 8 specific" HKS SSQV...or so said the seller. Does this mean my spring is adjusted for my car already?
the reason why i even considered it in the first place is because iv'e got a little bit of flutter at low rpms and i figure if i tighten the spring a hair it might reduce it.
it is not suppose to flutter, loosen until it stops unless your running high boost
Originally Posted by si_eater
DONT TOUCH THE SCREW, its supposed to flutter, its already adjusted to where it needs to be,mine does the same thing
heres where i got my info they say it flutters at part throttle, but malibu says you might be able to adjust a little,(i dont think i would touch it)
http://https://www.evolutionm.net/fo...ad.php?t=88637
flutter is turbo surge. they do flutter and it is hard to get them not too. i went through 3 bov's before i found one that didnt flutter.
oftheheavens
60
Jan 7, 2013 11:44 AM
Mooshu1221
12
Feb 2, 2005 05:14 PM
