V1 Hardwire: where is this wire?
Originally Posted by mooreboost
Huh?
That's what I did. Makes for a clean look.
how do you tap into the fuse box? I've never hard wired anything before and I think the how-to on this site is to much work for such an easy task.
but on a previous post someone said if we had a sunroof we could tap into a red/yellow wire that was leading to the sunroof or off of it?
staton
staton
I used the accessories fuse, so it came on when my key was turned to atleast ACC, or fully started. Right now, for some reason, I have it on a fuse where it's always on. It doesn't bother me nor does it drain the battery in any sense.
On their site they stress that the V1 has enough power, I wonder if 15 amps is enough.
You just need a little connecter from Autozone, it looks like a pitch fork, just pull a fuse and take it to Autozone, and match the width inbetween the prongs of the fuse with a connector. Then you just splice the wire, and crimp it into the connector, then place the connector into the fusebox slot.
Didn't know thos existed. Hence why I did mine the way I did, haha. It's a pain to get the fuse back in sometimes if you wrapped the exposed wire around it too much and made it thicker than it is. Have to shimmy it in a bit with a fuse removal tool. One of those little clampers.
But yeah *points up* That's how I did it. Been running fine for 2 years like that. Nothing has blown up.. yet :]
Originally Posted by thestaton
now that's what i'm talking about. good stuff guys thanks alot this went from a 2 hour install to about 5 minutes haha good good stuff!
staton
staton
The radar detector circuit won't need any special size fuse. It'll pull much less power than any of those numbers. You essentially pick a fuse that's big enough, but not too much bigger than the expected current flow. I'd imagine that the radar detector would draw just a couple hundred milliamps so a small 2.5A or 5A fuse is fine.
-N
-N
