Perparing to battle dealership
I had a new ACT clutch installled about a week ago. A couple of days after I got it back I was hearing this weird noise, a hum that would get louder the faster I went and when I would let off of the gas I would hear a grind noise.
so I took it back to the place I had the clutch installed and they told me that it's not the clutch that's making the noise but maybe the transfer case.
So now I have to take it to the dealer and I know I'm going to have to fight with them to cover the transfer case, if it is the TC, b/c of the aftermarket clutch.
Any suggestions????
Any suggestions????
Originally Posted by meanmud
Just be friendly and cooperative - more bees with honey type thing
Originally Posted by EvoJimbo
Did the shop that installed your clutch refilled the TC with fluids?
They usally don't drop the Fuild in the TC when doing the clutch I think it's a sealed unit I never see one leak when clutches were installed.
The shop I took it to, ATX Motorsports, said they checked the fluid after I took it back and they said that the fluid was very metailc looking and thick. They changed the fluid and it looked the same the 2nd time around. They said that it may be a bearing loose somewhere down there (sorry I'm not that technically sound). Anyway they dropped the fluid a third time and today they will check it to see what it looks like.
A TC case if over 2k and I don't think I should have to pay for it when I onlyl have 18k miles on this thing. Perpare for the worst and hope for the best
They can only deny the warranty if they can prove the TC problem is a direct result of the new clutch. Just go in and obviously dont mention the clutch and Im sure you will be fine.
After my Cusco twin-disc install, I also have been getting a very loud grinding noise under deceleration. I've been told by many shops, people, tuners, and people on this forum that the grinding sound is normal on after-market clutches... I don't think you have much to worry about.
I went to the dealer once and they told me the clutch was slipping and that they were not going to cover it. Is that information in a mitusbishi wide database. So If I go to another dealer can they pull up my file and see that I needed a new clutch a month ago and then make the connection that I got the clutch done recently??????
thanx
thanx
thanx
thanx
