VEIL / Blinder VS Stalker LZ1 GEN II
VEIL / Blinder VS Stalker LZ1 GEN III
Welcome to the first video to ever document the effectiveness of the Blinder M-20 Extreme and VEIL. In this video you will see the following.
91 Corvette
VEIL only with headlights down
VEIL only with headlights up
VEIL only with unprotected N.J. license plate
VEIL only with laser shield
VEIL only with laser shield / 1 coat of light supply of VEIL
03 Mitsubishi EVO VIII
Base Line test - no VEIL and Blinder M-20 Extreme OFF
Blinder M-20 Extreme ON - no VEIL
Blinder M-20 Extreme ON - and VEIL
2 in car videos documenting the V1 and Blinder.
00 Audi S4
The video run time is 19:51 and is 60 MEGS. This video is Copyrighted and can not be modifed or edited in anyway. If you have questions contact Michael Staton ( survey@d-rail.com )
This video was a blast to participate in and I cant wait for the next opportunity.
Thanks for watching!
Mike Staton
Video links:
http://www.kc8unj.com/radar/veil-blinderfinal.wmv
http://www.d-rail.com/test6140/veil-blinderfinal.wmv
Excel File: (Documents all the results in a easy to read Excel File)
http://www.d-rail.com/test6140/veil-blinder.xls
91 Corvette
00 Audi S4
Mike Staton
Video links:
Well, I guess I should of provided an explanation for the typical person who is not a enthusiast and does not know exactly what is going on.
This video was made to show that if laser traffic enforcement is used in your area then you have an option to defeat it. If you get hit with laser with just a radar detector it is to late. You should also know that if you get a ticket from laser you have a 99.9% chance of losing in court because its that accurate.
The laser gun used in this video is the Stalker ZL1 GEN III which is the 2nd hardest gun to jam. Other guns like the Pro Laser III used where I'm from are fairly easy.
These products I tested I stand behind 100% and will help you with any questions.
thanks again
thanks again
