jacking up the car
Old May 17, 2005, 12:48 PM
dohcvtec's Avatar
or, you can jack the front up in the middle. i do that on the metal plate under the motor, it has a little "knob" that is raised from the plate. although, it is not exact center, so one end gets raised a little higher than the other
Old May 17, 2005, 01:03 PM
Evoisdream's Avatar
who cares if it gets chewed up u cant c it and it doesnt effect anythign
Old May 17, 2005, 01:45 PM
damien ramirez's Avatar
just buy some rhino ramps for like 25.00. be safe and use wheel chalks ( those little wedge thingys )
Old May 17, 2005, 02:17 PM
oak2207's Avatar
My pinch weld is almost flattened out, looks real bad. I'm glad it's under the car and doesn't do anything.
Old May 17, 2005, 04:04 PM
herbal77's Avatar
in the center of the front of the car you can lift the whole front end with one point
Old May 17, 2005, 05:00 PM
HwangTKD's Avatar
I can see bare metal where that rail is chewed up. I dont want it to start rusting.
Old May 17, 2005, 05:05 PM
ddubb's Avatar
glad to see evom members using craftsman, i only use craftsman tools. I get all my friends discounts on their tools too b/c I work at the sears HQ.
Old May 17, 2005, 06:32 PM
rocketscience's Avatar
off topic, but that sears HQ is monstrous.. i was there a few months for TGI (The great indoors). It could be like the biosphere (self contained)
How much are those sears jacks? You can get similar jacks at harbor freight. They have various models with varying degrees of quality at various prices. variously.
Old May 17, 2005, 06:44 PM
BoostWhore's Avatar
I would personally jack from the suspension arm mount points its a lot more sturdy plus it doesnt chew it up. Nobody may see it yeah but if u bend it all up the paint will chip on it and cause it to rust...
Old May 17, 2005, 06:49 PM
plokivos's Avatar
you could actually jack up the front and back at a center spot. I can't remember what it's called, but it's a round spot.
rear too.
Old May 17, 2005, 07:12 PM
justchil's Avatar
Here is the floor jack.. its 120
http://www.sears.com/sr/javasr/produ...id=00950240000
Old May 17, 2005, 07:57 PM
EVO8LTW's Avatar
This is what I use. You can jack at the factory points without damaging the car. It's from JC Whitney and cost less than $6.
Old May 17, 2005, 08:02 PM
skiracer's Avatar
Well, however you jack up the car, put it on jackstands before crawling underneath the car just in case the jack fails and collapses.
Old May 17, 2005, 08:13 PM
Hiboost's Avatar
A block of wood seems to prevent the chew but that rubber piece for $6 looks like the way to go.
Old May 18, 2005, 07:30 AM
bolsen's Avatar
I don't see how that rubber piece would make it any more stable, other than it protecting the seam.
You could also use a hockey puck if you're worried about chewing it up.... but really people, those pictures are after jacking my car up 20+ times. I'm not trying to be insensative, but quit sweating the small stuff
Quick Reply: jacking up the car
