Boost Solenoid Restrictor Location?!?
Im fairly new to the evo and i heard removing the restrictor will make the evo boost at 21psi... im wanting to try it but not sure the location... this probaly has been covered a million times but i wasnt able to find it using SEARCH... so can anyone post some picture showing what lines to remove??? thanks in advance
Originally Posted by nrcooled
It's under the airbox.
Please just spend $75 bucks and get a hallman
true that, im sure you can gather some loose change and buy a mbc...... dont try to cut corners with a 30k car unless you can afford to, and in that case get a mbc!
Originally Posted by plokivos
ummmm,,,, are you talking about the boost restrictor pills? that's actually inside the hoses that connects the turbo, intake to the boost actuator.
it's PIA to take that off by the way.
https://www.evolutionm.net/forums/sh...d.php?t=114794
it's the green lines on the graph. Those lines have the restrictor pills.
no prob. glad i could help.
Optiblue
26
Feb 20, 2014 01:05 AM
smokedmustang
30
Sep 20, 2006 06:52 PM
turboex
Dec 1, 2004 06:17 PM
