HID upgrade problems!?!?!?!
Old May 30, 2005 | 03:24 PM
  #31
value's Avatar
No ballast change is needed. Does the flickering happen with your stock bulbs reinstalled ?? Try this to check your wiring and ballasts. Maybe you shorted out something during diasassembly. If it works with your stock bulbs your problem is solved.
Old May 30, 2005 | 04:41 PM
  #32
HIDPlace's Avatar
Ballasts have no effect on what kind of HID bulb it is, all it is, is a little computer which regulates the power going to the bulb, a 3500K HID bulb and a 12000K bulb use the same amount of power to work.
it seems that the bulbs were of crap quality and it seems like those "phillips" bulbs are knock-offs.
I've installed 8000Ks on to a buddies car 2 weeks ago and no problems with it. I say just try to get your money back if you can
Old May 30, 2005 | 09:18 PM
  #33
alby988's Avatar
dont they sella ftermarket ones?
Old Jan 18, 2011 | 10:42 AM
  #34
NocturnalEVO's Avatar
I know this is a really old thread, but wondering if the OP was able to get a proper solution?
I'm having the same issues in my car now..
- OEM HID's, I just upgraded the bulbs to 6000K's.
- About a year and a half later, my bulbs are flickering/strobing and then going out completely until I turn them off/on again, and the cycle continues.
Old Jan 18, 2011 | 10:45 AM
  #35
superman105's Avatar
which 6000k bulb did you replace with ?
there are 35w and 55w
also do you have stereo system in your car ?
jessemoody
Sep 13, 2015 08:44 PM
b0yw0nder
22
May 6, 2012 08:50 PM
jrod0187
32
Mar 7, 2012 08:12 PM
jwwu
38
Sep 13, 2010 10:24 PM
nigletsyz
71
Nov 17, 2006 02:10 PM
Quick Reply: HID upgrade problems!?!?!?!
