What should i be pushing???
What do you guys think I should be pushing for HP/TQ to the wheels with the following mods:
Buschur 3" Turbo back w/ test pipe
Buschur Intake
Buschur Upper IC
10.5 hotside
ported 02
Walbro 255 Fuel Pump
272/272 HKS Cams
boost set at 22psi.
Alky injection
Turbo XS Utec dyno tuned
Buschur Intake
Buschur Upper IC
10.5 hotside
ported 02
272/272 HKS Cams
boost set at 22psi.
Alky injection
Lower IC pipe or Upper will not give you any power at all with the stock turbo it helps very very little on bigger turbos 02 housing will help you very very slightly even with all the mods that YESEVO mentioned you maybe will gain 10 whp at the most ....
BTW I put down 373 whp and 386 Tq I just wanted to see if those where good numbers for my mods....trying to figure out if my tuning of my turbo xs was a good one.
