Problem with Greddy Bov
Hello all,
I just installed the Greddy Type-S bov with single spring mod but somehow I barely hear the whistle sound. It's not that as loud as I expected. Any infos/help would be highly appreciated.
Thanks~
Thanks~
Try tightening up the spring... that will help, but i will be the first to chime in, you dont need it for the sound. As long as its working properly, who cares about the sound
No I meant if you want the sound, use both springs. Mine used to be really loud but now with only the large spring its pretty quiet.
Originally Posted by BlueEvo04
I used the larger spring and now take out the larger one and put in the small spring?
Hello all,
Thanks~
Thanks~
ie , use 2 springs
https://www.evolutionm.net/forums/sh...d.php?t=113527
Former Vendor
turbo flutter cause the bov is to tight and not opening under slight throttle changes.. give works a call.. they seem to be the only company thats addressing this prob.. they recommened the the single spring mod with the second vacuum line hooked up..
not deafening like it would be if you run open air box or have an intake but its loud
but you definitely want to do the single spring mod
as long as it works.....who cares about the sound
