HKS Dynochart of USDM Evo 8
#31
Let me be the first to thank you
I dont' see a reason to get in trouble unless hks already done a jdm ecu match mod and those are the numbers? If it's stock the car shown here is much faster than 13.8 and maybe increase in hp from the one road and track tested
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
![Dunno](https://www.evolutionm.net/forums/images/smilies/dunno.gif)
#35
Originally posted by norcallancer
Actually, if the EVO dyno'd at 240 hp, which I am assuming is at the wheels, then the 271 BHP or at the flywheel is pretty damn accurate. When you figure you lose 10-15% of your BHP on the dyno, you would come up with about 230-240 hp at the wheels. Just like the USDM Lancer has 120 bhp but only dyno's at 103 to the wheels. Approx. 10-15% less. So if it has 240 to the wheels, then 271 BHP they advertise is correct. They "Aren't" lying.
#36
Originally posted by gtr
If it's hks dyno they use a dynojet. The highest numbers in town. If that is the case 271 sounds right on the spot. Sorry guys.
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
#37
rt turbo. Under your signature on the bottom you put A61 which should be A00 if you do not have a roof.
AWD do have more friction loss but even a wrx will probably have 190+hp on a dynojet vs 160+hp on a dynapack.
#38
Originally posted by s4awd
Here it is. It is for a stock USDM Evo 8.
#39
Admin Emeritus
The curve certainly shows the effect of a decreasing boost with increasing RPM! Imagine the curve with a MBC or modified ECU and a constant boost. Yum!
![Yum](https://www.evolutionm.net/forums/images/smilies/yumyum.gif)
#40
#41
For all you non-technical people out there and those who have never actually dyno'd oyour car, the Horsepower and Torque graphs are supposed to intersect at 5252 RPM. That is why the formula for deriving HP from TQ is HP = torque x RPM / 5252. This is not a real dyno graph, merely a translation of the actual graph. Would be nice to see the real one... Plus different dynos give different numbers, a roller type dyno like the 4 wheel dynojet shows more losses then the dynapack, but they measure different things.
#42
Busted
and it isn't even april 1st....now whoever posted that .....it is your responsibility to prove the info is kosher I'm sorry s4 didn't know you posted it.....I was just kiddin around anyway..
![Shooting Spree](https://www.evolutionm.net/forums/images/smilies/2gunsfiring_v1.gif)
#43
Originally posted by limey
Busted
Busted
They both roughly have the same value at 5252 RPM.
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
#44
Has anyone actually thought about the fact that maybe Mitsubishi found a way to get the power to the wheels without a huge loss in power for an AWD car? If so, I'd take that over 300hp at the crank, because guess what would happen when you really DO put 300hp to the crank?
![OMG!](https://www.evolutionm.net/forums/images/smilies/SHOCKED.gif)
#45
Originally posted by AutoXer
They won't "intersect" if their scaled differently... which they are.
he is correct at 5252 if they were scaled the same they would cross there
