High flow cat!
High flow cat!
Just wondering if anyone one else out there has had issues with their high flow cat on an aftermarket tbe exhuast tripping the service engine soon light. I am under the impression that the high flow cat isnt efficeint enough to keep the rear o2 sensor from thinking something is wrong. Not a big deal, just want to know. I am looking to get an o2 simulator to hopefully keep the cel from coming on.
Originally Posted by 8urv8
I am looking to get an o2 simulator .
use spark plug anti-foulers = https://www.evolutionm.net/forums/sh...d.php?t=114931
I have a high flow cat with my Buschur turboback and have no problems. Make sure you reset the ECU by unhooking the battery though. The changed response after the exhaust install will trigger a CEL.
I have a high flow cat with my Buschur turboback and have no problems. Make sure you reset the ECU by unhooking the battery though. The changed response after the exhaust install will trigger a CEL.[/QUOTE] I didn't reset the ECU right after installing the exhaust and before starting the car for the first time with new exhaust, if that's what you mean. It took a bit of driving the car around before it came on. If I reset the ECU now, the light will stay off for about 20 to 30 minutes, depending on the weather, then it will light back up. I assume it is because the o2 sensor takes that long to reach operating, then it trips the light thinking there is something wrong.
