e-manage part 2
e-manage part 2
Hey guys, I just got off the phone with Greddy and was asking about the new e-manage that is suppose to be coming out next month. they said the new unit will have true ignition timeing control and better algorithims on the fuel. but the best they they said the e-manage 2 will be able to self teach. In another words, install a wide band o2 sensor in the exhaust track, type in the a/f ratio desired and do a couple runds. then it self calibrates. and they said this unit will do everything and more than a stand alone. It will also data log the info. I guess it will do everything the exede will do but half the price. I also asked about the problem with the ignition coils burning and they said that will be eliminated. Just to let you guys know to is that Greddy has a new turbo kit that will be released soon. I believe it will be a 20g bb turbo. This unit is suppose to be better than the 25g or t67 unit that is out now. Better response than the t67 and have just as strong number.
I 'modified' my emanage to the new specs last weekend. The wbo2 is wired in and working brilliantly. The regular support tool doesn't do the auto-tune (AFAIK), and I can't get the new tool to connect (it's only a beta though).
Originally Posted by savageevo
992 do you still have the original e-manage? and yes it is the gold version.
hmmm, i didn't mind the emanage, but i sold it thinking they will never improve, BUT, if they prove to have something like Vishnu then maybe i'll have to purchase again, any other thoughts about this? Where are people hearing about this?
It's called the eManage Ultimate and it looks badass! I think it even has autotune capability and it uses REGULAR USB connections- no proprietary cables that lock out the self-tuner (finally a company that appreciates the little guy... plus they muast have seen that the cheap cones weren't stopping us from using the support tool software, but it WAS making them look like jerks for charging so much ) They fixed a lot of the firmware issues and a couple previously-additional harnesses are included onboard. I can't find my link, but I'm sure google will be able to help.
I think they retail for about $650.
http://www.mohdparts.com/emanage/ind...0Installation:
it doesn't say anything about an Auto-tune feature, unless i read through to fast
I guess I will spill the beans. Yes they do have a 20g turbo kit out because they used my car as the test mule. They installed the 20g with the t67 exhaust manifold ( for you t67 owners this 20 will bolt right in) external wastegate. But the kit that is coming out will have a cast unit. They installed there intercooler down pipe, exhuast, replaced the radiator with there own, ( they have replacement radiators now. very nice units) and injectors I think they were 620cc. All this with the old emanage they were able to get 350whp with a very, very, very light tune. They have said that the stock computer did very well in managing the a/f ratio. Last week they installed the egold and doing more testing this week. What I know is that the egold uses the actual crank signal instead of the stock ecu. It has its own injector drivers instead changing the resistance of the signal the stock ecu has. I has wide band data loging which it uses to self teach to disired A/F. And a lot of other features. I told them to get as much HP out of my car. They mention installing bigger injectors like 700cc. They are aiming 450whp, without cams. I should get the car back next week. I will try to post dyno numbers when I get it. the emanage will cost about 600.00. don't know how much the 20g kit will cost. I will keep you all posted.
