Headlight with intake hole
Old Jun 13, 2005, 03:54 AM
iwtfyaz's Avatar
is it possible to get this headlight?
Old Jun 13, 2005, 03:57 AM
donmeca2020's Avatar
doubt it , thats for the road racing evos.
Old Jun 13, 2005, 04:00 AM
350Z_2_Evo8's Avatar
Anyone knows how to make that hole? i would like to do that...since the 05 GSR dont come with fog lights...
Old Jun 13, 2005, 05:29 AM
NoEVOYet's Avatar
Could probably use a Dremel to make that hole. Trace out the shape you want, hold your breath, then cut away!
Old Jun 13, 2005, 05:35 AM
Rez90's Avatar
i wouldn't do it.....cause regardless if you cut into it and it works or not...you still have broken the headlight seal and you would have to seal it throughout the entire inside of the hole.
if you're that serious about making power...just remove the headlight prior to competition and put it back in when you're done
Old Jun 13, 2005, 05:36 AM
tke_413's Avatar
There's got to be a way one of these vendors can get there hands on some of these
Old Jun 13, 2005, 06:08 AM
MR 600's Avatar
Group buy !
Old Jun 13, 2005, 06:10 AM
Kwman's Avatar
Just make power by an already proven way...more mods. This is probably the most time consuming search you could do. Its not worth it imo.
Old Jun 13, 2005, 09:08 AM
RalliArtEvoVIII's Avatar
call garage hrs
Old Jun 13, 2005, 09:10 AM
brandon's Avatar
bump
Old Jun 13, 2005, 09:13 AM
nutrulz's Avatar
I'd get it.
NocturnalEVO's Avatar
IT can be done fairly easily, however to get the front to look all pretty like that will take some skills
Old Jun 13, 2005, 10:19 AM
instigator's Avatar
I'd give up my foglight for that.
Old Jun 13, 2005, 10:22 AM
evodave's Avatar
Location: driving the 10 second beast in ohio or running lightmods.net
i am in the process of trying to find or make a duct like that.... i will have a spare headlight shortly to use so i need to get or make the ducts. I may offer it as a addtional service ontop of what i already offer if i can get it down properly and sealed up right.
Dave
Old Jun 13, 2005, 10:39 AM
chaotichoax's Avatar
evodave clearly is the man haha
Quick Reply: Headlight with intake hole
